Cleaning a Monotype Metal Pot
Started by John Cornelisse, June 07, 2022, 09:53:32 PM
0 Members and 19 Guests are viewing this topic.
It is far better to take the nozzle off the pump, before you put the piston inside the pump. Than the lead will not have much power to reach the attic.
actually, every time when a casting job is finished, the piston should be removed from the pump, that will remove most lead from the nozzle, thanks the vacuum, when the piston is raised.
After that the nozzle should be taken off. The nozzle can cool down.
Next time before the casting starts... the nozzle should be drilled and cleaned.
Also the oxides that will cover the liquid lead, need to be taken away.
Each year, you need to clean the pot, take the pump out, remove all molten lead, and take away the heating elements, and clean those, and remove all oxide at the walls of the pot.
When this is not done regularly than the oxides will grow around the heating element, and after some time this can be so much that the elements might be overheated.
Jason
John, this should likely be a new topic, but I just read your signature note about cleaning the pot. I hate to admit that I've never, ever done this, and I doubt Jim Rimmer did either when he had the Super. I've often wondered how this is done.
I understand that to empty the pot is fairly easy: get it liquid, turn it off, scoop out all of the metal, wait till it cools completely, then remove/clean the elements.
But then what? Once the elements are reinstalled, how do you fill the pot back up? Would you need to melt metal and then pour it into the pot? That makes the most sense.
Also, how does one clean the elements? I'm very hesitant to do anything to them, as I only have one set and do NOT want to damage them, but your note suggests that I'm likely damaging them by doing nothing.
Any feedback/instructions would be very much appreciated.
Best,
Jason
Just pack the pot with the small ingots and fill the empty spaces with old type, turn it on and as the metal melts, replenish it using a regular "pig" (long ingot) later on.
Cleaning is best done with a steel brush after the pot is cooled down. Unscrewing the pump fixture and heater holders on the top of the pot is easier when hot and not always that easy; be sure to use a screwdriver that fully engages the slot. Sometimes a bit of WD40 helps too.
When I was in America together with Dan Jones, at Richard Hopkins place. We found several machines completely filled with oxides around the heating elements.
One of them needed an hour to melt the pot... It proofed one part of the heaters was not hot at all. Because it could not get rid of the energy... It had burned down.
We could replace the damaged part, but the cleaning needed quite some time. After this I looked through all other machines, all of them had quite some oxide inside...
I cleaned 4 of them before we went back to Dan Jones place...
When the elements are completely covered with oxide it is rather difficult to get it from the elements. And you must be careful too. You do not want to hurt the elements...
When the cleaning is done on a regular basis, at least once a year, it is far more easy to do this job.
The linotyper's at this site should also be careful with the heaters in the pot. There is less tin and antimony in the lead, but oxides will grow there also.
Also they should clean the pots on a regular basis.
Jason
To clean the elements, do you remove them? Or just try to brush them clean while they're still installed?
Also, steel-bristle or brass-bristle brush to clean them?
Jason
After taking out the pump and all the liquid metal, lots of oxide can be removed when the pot is still hot.
When the pot is cooled completely, than it is a lot harder to remove all oxide. You might need a screwdriver and an hammer to crush the oxide. Be careful: the heater element should not be touched by this at all.
Remove the screws that hold the heater in place. Under these holders oxide is growing too.
Take the heater-elements out and brush them clean if needed.
After the pot is clean, the machine can be rebuilt.
The elements are probably encased in some steel alloy. Any sort of brass/copper/bronze would contaminate the metal in the pot, and aluminum would be out of the question for any of several reasons. This means they are pretty tough so you could use either a brass or steel brush.
The oxides are often held in place by type metal, so cleaning them off hot might work better, at which point a rag could wipe off most of the deposits. You could heat them with a torch, or just by judiciously applying power to them. You ideally don't want them hot enough to glow though.
Brushing off the oxide will generate a lot or airborne dust, so I would generally be satisfied with removing the larger accretions. The elements don't have to be sparkling clean.
I think you could go a long way cleaning the pot without draining it by using a thin metal strip (a piece of hacksaw blade with the teeth ground off?) to dislodge oxides that have collected between the element and the pot. Another blade with a 90 degree bend in the end about 1cm long could clear the area between the element turns (reaching from inside the pot, don't try pushing this between the pot and element as it might get stuck!). The dislodged oxides should float to the surface, so flux and skim occasionally as you do this to remove the oxides.
Alembic Press
I use an old kitchen knife, to poke down between the elements and the pot wall.
When I had to rebuild one of my composition caster pots a few years ago, to replace all the collapsed asbestos lining, I had to remove the elements, and seem to remember getting the element clamps off was a struggle, as none of the screws would move. I had to drill out most of the screws, same for some of the other screws that held parts on the pot. Luckily I was able to get a friend to retap all the screw holes. And I relined the pot with a non-asbestos lining. All back together and working, but the Funditor bourdon tube is not as accurate as it was, so I may have to replace that with either a spare, or with a solid state controller. Am about to build one such for my super caster, and will see how that performs.
There is always something that needs doing on these machines!
Here is picture of a clean pot on my Super Caster, that John and I worked on. Sorry, I didn't get a picture of it dirty, however all the elements were covered in oxides. Also oxides collected between the elements and the pot wall, solid. In fact, if you see the cast iron post in the bottom of pot, there was one on the left side that was busted off due to all the crud. When the element heated up, it expanded and actually broke the cast iron boss off. I was lucky not to loose the element.
Note we had to bend the tabs to get the elements out, later, we managed to loosen the screws, not an easy job. I recommend taking the elements out, they clean up without much trouble.
Jason
Hi everyone,
If you're following my other thread "Really Bad Type . . ." you know that one suggestion to my Really Bad Type problem is that I have zinc contaminated metal. So, I want to do what you've all described in this thread.
You've all provided really useful information about getting the elements out and cleaning them, or cleaning them while they're in hot metal, but my main question is the obvious one:
How do you drain the pot?
Is it just a matter of scooping it out with a ladle?
I assume the elements should be turned off, so they're not exposed as the metal is removed, but I'm concerned the metal will start to freeze when I have the pot half empty.
And how to you get the last 1/4 out with parts still in there (the pump operating mechanism, etc.)?
This likely sounds like an obvious process, but I'd appreciate any suggestions/instruction on doing this right.
My plan is then to cook up some type in my cauldron to have hot metal ready to pour into the cleaned pot. I can't trust any of my ingots, as they, too, may be contaminated.
I really appreciate this forum and benefiting from all of your experience and knowledge, so thanks in advance!
Jason
Jason,
Ladling it out is indeed the method to use. Clearly you can't detach the hot pot and pour it out, and siphoning it out would be more dangerous for lead poisoning than siphoning (leaded) gasoline!
You have to get the pot hot enough that the metal remains molten until you are done emptying it out despite having the elements off while ladling. I suppose you can keep the heaters on at first but if the exposed heaters start to glow it is time to turn them off. The heaters should actually be able to glow safely but why tempt fate? Once they're out of the metal they don't help keep it molten anyway, all the do is keep you hot!
You will probably want several sizes of ladle to work with, a big one to get most of the metal and a smaller one to get the last dregs. Make sure you preheat them both (leave the small one in the pot while using the large one).
There will always be a small puddle that you can't ladle out, but you should be able to get it down to a small puddle in the well, and it should be possible to remove this once it has solidified, especially if you leave a tool in it as a "handle".
As the level is going down in the pot you can progressively clean off the metal/dross "slush" stuck to the hardware in the pot, but don't be too fussy about it because the cooling metal in the pot limits your time. Any of this that you miss on the heaters can be loosened by running the heaters for a few minutes on the empty pot; again, turn them off if they start to glow.
I documented my experience emptying and refilling my caster's pot on my blog.
Both John and me always took the pump mechanism out before emptying the pot for thorough maintenance. It takes some work, but it's necessary if you want to take the heating element out... which is much advised as the oxide likes to build up between the element and the pot's wall.
Jason
Kevin, thanks so much for the link to your blog! It's more helpful than you think because, like you, one of my elements pokes up out of the surface of the metal, and I've likewise had to keep the pot VERY full to try to keep it submerged, but even then it often sticks out.
Your photos also show the pump support arms with the metal out, which is also really helpful.
And your instructions are very clear, simple, and, well, obvious now that I've read them, so thank you for spelling it out.
Now, why did I not realize you had a Super? I thought it was just Dan and I in Canada with Supers? Great to know there are three of us!
Now, next up, I had a look at your "For Sale" page and see you have extra pistons, which is amazing, as I've been very eager to get my hands on a spare. Your third photo shows exactly what I'm looking for: the f13SHH piston with the short d13SH1 head. Do you by any chance still have that piston available? If so, please let me know via email (are you still at the thinkage.ca address? or should I use your papertrail.ca address?).
For the moment, though, thanks so much for your reply and blog post on emptying the pot!
Jason
Somewhere I did read something about lead-poisoning from KPMartin...
Lead is dangerous in many ways, the powder we take of the pot, after cleaning the surface we do not want to inhale it.
But in the past we were warned for "Lead-Fumes".
Actually lead won't vapor at the temperatures we use, lead will not kook before 1500 degrees celcius.
Adding Tin and Antimony let the lead melt much earlier... And the lead molecules do not vaper.
The most polluting dust in our workshops, is the carbon dust, that is burned from the oil fallen into the molten lead in the pot.
We all should start with a blower, to remove the air above the pot.
You might control your workshop, everywhere you might find some black dust... Inhaling this dust might even  cause cancer too.
