Welcome, Guest. Please login or register.
September 06, 2010, 06:33:07 AM
1019 Posts in 316 Topics by 136 Members
Latest Member: handandeyeletterpress
Home Help Search Login Register
Metal Type: Home| Photos| Stories| Downloads| Forum| Classifieds
Books about Letterpress Printing and Printing History
Metal Type Forum  |  Hot Metal Talk  |  Technical Help  |  Kluge Feeder Adjustments « previous next »
Pages: [1] Print
Author Topic: Kluge Feeder Adjustments  (Read 517 times)
Administrator
« on: March 14, 2008, 02:50:29 PM »
Blair Wolfe contacted me by email with the following technical enquiry:
I have recently acquired a 12 x 18 C&P with a Kluge feeder and foil draw for foil stamping. I also need to do some short run die cutting, scorring & perforating from time to time. Does any one have any good information about the correct adjustments of the feeder unit for dependable feeding? We have instaled a good vacuum/pressure pump to get good pick up ability, but the suckers appear to run too close to the feed table, and I think there is probably a lot of small adjustments that they would have made in the old days. Does any one go back that far?
Anyone with expertise in this area?
Report to moderator   Logged
Click here to receive an automated daily email of new posts on this forum.
Seen a post that shouldn't be here? Click the "Report to moderator" link underneath - it works!
Jeff Zilles [jeffo]
Moderator
WWW
Re: Kluge Feeder Adjustments
« Reply #1 on: March 16, 2008, 06:04:42 AM »
I cut my teeth on a 10" x 15" version of the same animal but without the foil gear and have the highest regard for the general usefullness and versatility of the machine.
I have never sighted an instruction book or even a hint sheet for the feed and delivery systems of the Brandjen and Kluge add-on for C & P though I suspect there must be something writ somewhere which would give the basic dos-and-don'ts.  The rest is common sense and experience gained daily.
Every change of stock type or size may need a different setting though once the feeder is set up properly the changes in most cases are usually of a minor nature.
Where is the machine situated??
That knowledge made public could inspire an ageing machinist not too far away from wherever to spring out of his/her bath chair and accept the challenge to instruct.
Again - great machine - this is the unit that most times will handle the jobs that give trouble on the Heidelberg Platen and British Thompson --- I have had them all and consider that ideally, you can do with one of each.
jeffo
Andy Keck
Guest
Email
« Reply #2 on: June 26, 2008, 05:54:23 AM »
I'm still removing decades of semi-solid crud from my Kluge, so I'm not exactly a wellspring of information. I can say that I've found the manual on the Boxcar Press site to be helpful. With my press, I also received a similar photocopied book of instruction.
http://www.boxcarpress.com/community/manuals/kluge-operation.pdf
Better yet, the George Mills book, Platen Press Operation, has a section on the Kluge feeder that looks like it will be useful when I'm done cleaning and ready to start printing.
Jimbo
Tea Boy
« Reply #3 on: October 20, 2009, 01:40:05 AM »
 ::)If someone could enlighten me with regards to the Kluge Feeder I might be able to answer quite a few questions with regard to same.  My question is... is this the same feeder setup as installed on the Kluge presses?  If so, we're in good shape.  Those I have to deal with on an almost daily basis. (And for these past many years).  Let me know...
Jimbo
Pages: [1] Print
« previous next »
Jump to:
