Author Topic: Unit shift  (Read 312 times)
  • Moderator
  • 31/10/2014
Unit shift
« on: May 14, 2020, 04:36:03 PM »
Is there somebody who knows what kind of codes the unit-shift attachment is using ?
I guess the E- and the D-signals are used for it...
I would like to know where the connectors for the attachment are located... Before I start a search for them.
The Monotype manuals are not very informative for this kind of things...
Keri Szafir
  • Old Hand
  • Monotype Geek
  • 26/01/2016
    • rpi2caster blog
Re: Unit shift
« Reply #1 on: May 14, 2020, 08:27:04 PM »
D shifts the row
E+F addresses column D
and that's all.
Use the little knob below the paper tower to turn the thing on and off.
One tube surely goes to the additional long pin (that pushes the diecase draw rod into the upper socket rather than lower) in the front pin block.
There's an air valve actuated by one of the cam levers (springbox one if I recall correctly) that delays the air flow to the additional pin, so that the diecase is shifted in a proper phase of the machine cycle.
Signals D, E, F from the paper tower, output to D pin and the air mains go to that block too. I don't know how your machine does it (it's slightly different than ours when it comes to the location of the unit shift switch), but it looks like the quadding and centering attachment pass through that block on ours. That's probably just a passthrough with no signal split, though. Only the air mains seems to be split.
"10 most common mistakes made by beginner programmers: missing semicolon, undeclared variable and an off-by-one error."
Technical specialist at Book Art Museum, Lodz, Poland
http://book.art.pl/index.php/en/
  • Moderator
  • 31/10/2014
Re: Unit shift
« Reply #2 on: May 15, 2020, 11:29:33 AM »
Thanks, for the info.
I got some patent papers from Dan Jones in Canada too, those contain some drawings of the tubes too.
I need to figure out the connections, on my machine the E and the D are not working, and I need to find the place where the tubes should be connected.
From this machine the attachment is taken off.... I will figure it out. At presently I need to change the layout of the die-case a bit to be able to use it on this machine.
  • Moderator
  • 31/10/2014
Re: Unit shift
« Reply #3 on: May 15, 2020, 02:41:04 PM »
At this moment, the E- and D-pins react properly. I still need to find the connections for the D-pin.
A litle experimenting and a solution will occur.
